Activity › Forums › Adobe After Effects › Bullet Sparks with CC Particle World
Posted by Patrick Bottaro on July 6, 2008 at 6:18 amDoes anyone know how I could create a bullet ricochet off metal spark with CC particle world?
Kevin Dearing replied 18 years, 2 months ago 3 Members · 2 Replies -
Jeremy Fabiano
July 6, 2008 at 5:14 pmI dont remember specifics, but you’re gonna wanna keyframe the birth rate so you have a “splash” of particles and then they die off…
you’ll prolly wanna move it around (the emitter) and turn the gravity down a little bit..
color correct the crap out of it and it should work out..
Hope this points you in the right direction..
-Jeremy
Kevin Dearing
July 17, 2008 at 5:33 pmLike Jeremy said, but you could also use 32 bit color and the glow effect to get that sparky look..
Andrew Kramer has a tutorial which creates sparks – I forget which particle system he used for that but the net effect is the same (the tutorial is titled ‘3d sparks title’ but the sparks can be applied to your bullet hits instead of text..
https://www.videocopilot.net/tutorials.html?id=107
–KTFA
