Activity › Forums › Boris FX Particle Illusion › Bullet Effect
  • Thomash Lee
    May 4, 2006 at 7:57 pm
    https://www.geocities.jp/ifurkend/bullet-time.zip
    This effect requires 2 specific function of PI3 (byebye PI:SE), Super Emitter and Get color from background.
  • Jose Burgos
    May 4, 2006 at 7:58 pm
    https://www.burgos-family.com/movies/joseburgos2003.wmv
    The bullet was done in Lightwave.
    All other was done in PI.
    Rings emitter was modified to make the trail.
    Jose Burgos
  • Sam Rose
    May 4, 2006 at 9:04 pm
    Diony, the bullet-time.zip when I open it there is nothing on the screen, the emmiters on it are Fire Blast which I don’t have. Where do you get it? Thanks.
  • Sam Rose
    May 4, 2006 at 9:07 pm
  • Alan Lorence
    May 4, 2006 at 9:21 pm
    Since it uses “get color from layer” for the particles, you need to load an image or movie or you won’t see anything.
    Alan.
    wondertouch
  • Sam Rose
    May 4, 2006 at 9:30 pm
    the effect still does not work, when I load it, it says the File E:/illusion3/bg.bmp was not found do you want to look for it YES/NO, if I click yes and open up a image it says ” The images for Layer : Layer 0 has been removed” when it loads there is nothing on the screen even when i press play, it is the same if I click NO. Is there any other way of creating a bullet with the trail effects in slow motion?
  • Alan Lorence
    May 4, 2006 at 9:38 pm
    Load your own image. Sounds like you need to study this page a little:
    https://www.wondertouch.com/quickstart.asp
    Alan.
    wondertouch
  • Sam Rose
    May 5, 2006 at 3:29 pm
    Hi
    Got it to work but that is only a bullet trail, it’s cool, but is there any way of me getting a bullet aswell?
  • Aharon Rabinowitz
    May 5, 2006 at 11:42 pm
    If you use after effects, I cover this effect in my Creative Cow Master Series DVD, particleIllusion Fusion – Volume 1.
    http://www.creativecowtraining.net
    I basically use particles along with diplacement maps.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Aharon Rabinowitz
    May 5, 2006 at 11:44 pm
    Forgot to mention, if you watch my tutorials on diplacement maps (just click on my head to go there) they will give you an idea of how displacement works – I think this will really help you.
    Aharon Rabinowitz
