Activity Forums Adobe InDesign Bullet Baseline Shift using Nested Styles
  • Bullet Baseline Shift using Nested Styles
    Posted by Vincent Rosati on January 16, 2008 at 6:41 pm
    I’m trying to make a 2pt baseline shift to a bullet/bullets.
    I have a Paragraph Style that applies the bulleted lines, and I’ve created two Character Styles; one that holds the zero baseline, and another that adds the 2pt baseline shift.
    Now I try to add these two Nested Styles to the main paragraph style, and I can’t get it to work.
    I’ve basically seen two solutions for this…
    1-Nested Styles
    2-Java Script
    I’m more comfortable with Nested Styles. Can someone explain how to do this, or is there an easier solution?
    Thank You
    Vince
    Vincent Rosati replied 18 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
