Activity Forums Adobe Premiere Pro Bulk removing / disabling effect
  • Bulk removing / disabling effect
    Posted by Marc Nibor on July 24, 2017 at 11:45 am
    I have a quite complex project with around roughly 600 snippets. Each one of them has the “Clip Name” effect activated. Soon I will start rendering the Final Cut… and I am looking for a simple workaround that allows me to quickly disable/remove the effect on every single snippet.
    Any ideas? Thank you.
    Marc Nibor replied 9 years, 1 month ago 2 Members · 2 Replies
  • Simon Ubsdell
    July 24, 2017 at 1:02 pm
    Select all your clips and either right-click and select Remove Attributes or select it from the Edit menu.
    You can then choose which attributes to remove, in your case make sure Clip Name is selected. Make sure to uncheck any effects etc. that you don’t want to remove.
    Simon Ubsdell
    tokyo productions
    hawaiki
  • Marc Nibor
    July 24, 2017 at 1:07 pm
    WOW! Thank you Simon. That is a truly great solution!
