Activity Forums Apple Final Cut Pro Bulk Meta/tag/keyword edits
  • Bulk Meta/tag/keyword edits
    Posted by Andrew Johnstone on November 13, 2020 at 10:01 am
    Hello Chums,
    Hopefully this is an easy one…
    I have a series of similar films that I am laying in different voiceover language versions for. I want to be able to tag them all with the same keywords so that I need to spend less time tagging each film. I am currently copying and pasting key words from from a text file into the ‘tags’ field, but I’d like to be able to tag multiple projects/edits all at once.
    I have looked for tips on line, but can;t find anything. Any ideas?
    Andrew Johnstone replied 5 years, 9 months ago 2 Members · 7 Replies
  • 7 Replies
  • Jeremy Garchow
    November 13, 2020 at 11:08 am
    Hi. Maybe can you explain what you have tried? You can select multiple elements in the browser, open the keyword editor, and type a keyword (or assign one to a shortcut and hit that shortcut) and the keyword will get applied to everything that’s selected. Is that not working for you?
  • Andrew Johnstone
    November 13, 2020 at 3:18 pm
    Meta is not something I have really paid much attention to although I know that is what FCPX is supposed to be good at.
    At the moment I am changing the Tags for each film as I ‘share’ them. Will the Keyword editor do this for me?
  • Andrew Johnstone
    November 13, 2020 at 3:36 pm
    Ah…just figured out how to add Keywords to multiple projects (handy…!), but these do not see to show up as ‘tags’ in the info panel when I am trying to Share the clips . Copying and pasting the tags is easy enough, but when i have 20 films to spit out it is better to be able to automate this…
    Thanks for any help.
  • Jeremy Garchow
    November 13, 2020 at 4:38 pm
    You can select all the Projects, and write the Tag and it will update all of them.
  • Andrew Johnstone
    November 13, 2020 at 6:42 pm
    Yes I tried that…
  • Jeremy Garchow
    November 13, 2020 at 8:24 pm
    And it doesn’t work or…?
    It works here.
  • Andrew Johnstone
    December 1, 2020 at 4:25 pm
    Sorry for the delayed reply…never really figured this out BTW. I can successfully Keyword multiple projects but cant see how to tag multiple projects so that they are all tagged when I want to export (“Share”) the project.
