Activity Forums Apple Final Cut Pro Legacy Bulk adjusting of stills
  • Bulk adjusting of stills
    Posted by Dan Hayes on September 30, 2010 at 1:12 am
    Hi All
    Doing a job with hundreds of stills. Is there any way to change the duration of group of selected stills in a bin and is there a technique to remove all the dissolves from a group of selected clips in a sequence?
    Dan
    Andreas Karoliussen replied 15 years, 11 months ago 2 Members · 1 Reply
  • Andreas Karoliussen
    October 1, 2010 at 6:59 am
    Hi Dan,
    -In your User preferences you can sett still duration in the edit tab.
    -Removing multiple dissolves is easy – select the part of the sequence with draging a lasso to mark your clips. Set an inpoint at the start of the first clip you have selected.
    Drag the selected clips into the canvas and over to the “overwrite” that pops up.
    HTH
    Andreas
