Bulk adding titles
Posted by Jithendria kumar Aravamudhan on February 8, 2016 at 7:34 amIs there a way to attach a title video to a bulk of other videos in Vegas?
Jithendria kumar Aravamudhan replied 10 years, 7 months ago 3 Members · 4 Replies -
Wayne Waag
February 8, 2016 at 4:40 pmInteresting question. Using just Vegas, I don’t think so. However, if you have Vegasaur, it’s quite easy. Using Transcoder, add videos, select rendering template, and output location. Then under the BOLT tab, you can add a leader or trailer. In your case, you would add a leader. Using this approach, there is no need to actually import your videos directly into Vegas. If you don’t have Vegasaur, I believe they still have a 30 day free trial. Good luck.
wwaag
John Rofrano
February 8, 2016 at 6:00 pm[jithendria kumar aravamudhan] “Is there a way to attach a title video to a bulk of other videos in Vegas?”
Vegas Pro Production Assistant was designed specifically for this kind of batch workflow. You can very easily set up a template with the title video and a slug to represent the video. Then point it at a bunch of videos and it will substitute your video for the slug and render in multiple formats, with each video you give it.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com -
February 8, 2016 at 6:46 pmThanks a lot Wayne. Will definitely try this.
