Activity Forums Adobe After Effects Bulge effect on text
  • Bulge effect on text
    Posted by Lisa Olshanski on August 9, 2016 at 7:24 pm
    Hi All- I am using a bulge effect on text to make it look like it’s going around a horizontal cylinder. It is making my text look really weird. See attached. The type is a vector file from photoshop scaled down to 35% in AfterEffects. I put a 10% blur on the text to try to cut down on the bulge effect weirdness. Look closely at the edges and some circular thing going on. Any thoughts?
    MacBook Pro- Mac OS ver. 10.10.3- Processor 2.5GHz- 16GB memory
    Final Cut 7
    Adobe Premiere CC
    Sean Dunn replied 10 years, 1 month ago 2 Members · 4 Replies
  • Sean Dunn
    August 9, 2016 at 7:36 pm
    Here’s a pretty decent tutorial on how to do what you described using CC Cylinder instead of the bulge.
    https://vimeo.com/5943840
  • Lisa Olshanski
    August 9, 2016 at 7:47 pm
    Thanks Sean. I tried that. I need the type to move kind of like an odometer or slot machine. Not individual numbers moving but all the type moving around a cylinder in that direction. Thanks though!
    Final Cut 7
    Adobe Premiere CC
  • Lisa Olshanski
    August 9, 2016 at 8:17 pm
    Hi again Sean- I figured out how to do that but it doesn’t give me the nice effect I get with Bulge.
    Final Cut 7
    Adobe Premiere CC
  • Sean Dunn
    August 9, 2016 at 8:40 pm
    Ah okay, sorry I misread as needing help with the initial effects.
    For the weird dots, did you double check for the continuous rasterize button? Possibly use a illustrator vector file instead of a photoshop one?
