Activity Forums Apple Final Cut Pro Legacy built in Mic
  • Posted by Mark Dannunzio on January 9, 2006 at 6:45 pm
    Ok, boys and gals,
    just need a quick voice over in FCP. I have a mic lined into computer but the audio levels SUCK when I try and record into Final Cut.
    Computer audio is boosted all the way up and all my audio levels under system preferences are set right. Doing anything wrong? Or is it FCP
    Thaks
    -Mark
    Jack Fox replied 20 years, 8 months ago 5 Members · 6 Replies
  • Matthew Brunn
    January 9, 2006 at 7:21 pm
    MAC AUDIO INPUTS ARE LINE LEVEL NOT MIC LEVEL. YOU NEED TO BOOST THE SIGNAL BEFORE IT HITS THE MAC. TRY https://www.griffintechnology.com/products/imic2/
  • Shane Ross
    January 9, 2006 at 7:27 pm
    You also need to keep the caps lock off so that you don’t look like you are shouting.
    Yeah, the signal needs to be boosted. I use a Shure mic and a Mixer routed thru my capture card, but that is a more expensive way than the one Matt shouted about.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Matthew Brunn
    January 9, 2006 at 7:35 pm
    Sorry for shouting, I was rendering in AE.
  • Steve Denn
    January 9, 2006 at 7:38 pm
    Mark
    You’ll need a product called Imic from Griffin. I had the same problem. https://www.griffintechnology.com/products/imic2/index.php
    TD/Production Editor
    WJBK FOX2 DETROIT
  • Shane Ross
    January 9, 2006 at 7:40 pm
    Matt shouted…er…mentioned that.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Jack Fox
    January 9, 2006 at 7:43 pm
    All true if you’re using a PowerMac. But if you’re using the PowerBook built in mic you need to move closer or connect a regular mic directly into the PowerBook (imic not required).
    jmf
