Activity › Forums › Apple Motion › Building the perfect DVD
  • Building the perfect DVD
    Posted by Dave Montague on January 30, 2009 at 1:53 am
    Ok, I am in Motion and I want to create the perfect DVD. I have Studio Pro 5 so I am ready to go. Please share with me what are the optimal setting for a good quality DVD:
    1-What resolution should I use to compose in Motion? The video was shot in HD. I want this to play on everyone’s DVD home player if possible but I do want it is HD.
    2-What compressor Setting should I output these videos in?
    Keep in mind I want a great quality DVD. I don’t want to spend hours compressing at the highest resolution if I don’t have to.
    Andy Neil replied 17 years, 8 months ago 2 Members · 1 Reply
  • Andy Neil
    January 30, 2009 at 11:00 pm
    Ok, I’m going to go ahead and assume you’re talking about making an SD DVD as opposed to an HD-DVD or Blu-ray.
    Given the fact that your final DVD will be 720×480 in size, your Motion graphics need not be any bigger than that. However, this doesn’t mean that you should export your Motion project using a lossy codec like DV. Instead use the highest quality codec you can like Uncompressed 8 or 10bit.
    DV codec is notoriously bad at handling gfx so stay away from it if you can.
    Export a QT movie and then let Compressor do the MPEG compression. There are presets available for DVDs based on length of project.
    Andy
