Activity Forums Adobe After Effects building on the water
  • building on the water
    Posted by Rafael Amador on March 27, 2007 at 12:10 pm
    I’ve posted this in the FC’s forum, but I think here I can get more advicing.
    I wan to get the shape of a ancient building reflecting on the water of a river. How to get a natural look. I’ve got FC and AE. Any suggestion help would be warmly appreciated.
    Rafael
    Rafael Amador replied 19 years, 6 months ago 4 Members · 4 Replies
  • Mike Clasby
    March 27, 2007 at 1:51 pm
    If the building is on its own layer (building only), you might try duplicating the layer (Ctrl D), then Distort>Corner Pin to get the angle of reflection, then reduce the aopacity (20%-30%). If the building is not on it’s own layer, you need toduplicate the layer, then mask it out with the Pen Tool, fether a bit then do the above.
  • Danny Princz
    March 27, 2007 at 2:38 pm
    you could go one more step and you find some water footage and set that as a displacement map.
    done right, and this will add just that extra little bit to make it look nicer
    who is that masked man…
  • Rogerm
    March 27, 2007 at 4:44 pm
    and play with the blending modes…
  • Rafael Amador
    March 27, 2007 at 5:12 pm
    Thanks for the ideas. i will start to work with the Displacement Map.
    cheers,
    rafael
