Activity › Forums › Avid Media Composer › Building an Avid Media Composer/SDI interface Portable system
  • Building an Avid Media Composer/SDI interface Portable system
    Posted by Hellis on October 15, 2007 at 8:44 pm
    I want to build a portable system based around Macbook Pro (Firewire 400 only) and Media Composer. Need to input/output to Sony digibeta. I have mixed feelings about Mojo, although I have not used Mojo SDI. Any recommendations for 1: SDI Interface 2. Inexpensive but reliable firewire drives 3. Lightweight monitor for 2nd monitor? Price is defintely a factor!
    Brendan Thompson replied 18 years, 11 months ago 4 Members · 3 Replies
  • Accountfrozen_needs_realname
    October 16, 2007 at 7:09 pm
    To the best of my knowledge, you have only two SDI interface options. One is an SDI Mojo box, and the other is an Adrenaline DNA box.
    If the Avid software will speak to any others, I do not know about it.
    Jon
    _______________
    Lack of preparation or organization on your part does not constitute an emergency on my part.
  • Flake Shaw iv
    October 17, 2007 at 1:07 am
    I believe John is correct about the SDI options for Avid, the mojo is the only interface I know of as well. The “nice” thing about the mojo’s these days is that Avid will overnight you a new one if you do encounter a problem. You just have to be able to convince them that the problem is mojo specific and not a compatibility issue with other gear.
    As for FW drives, if you’re looking to go cheap, go cheap enough to buy two of the same ones so you can actively back-up and swap drives in case of failure. The cheapest drives I’ve found are the LA Cie refurbished drives, but I use them for transfer only and don’t work off of them. G-Tech’s G-Raid drives are extremely reliable, but more expensive.
    Are you looking for HD or SD monitors? Try local post houses or rental companies and see if they have any older models they will off-load. Sony LUMA LCD series has some cost effective, smaller models. Wouldn’t recommend for on-line, but they do the trick for off-line.
  • Brendan Thompson
    October 17, 2007 at 11:50 pm
    Mojo SDI is good and your only option.
    I buy only G-tech (no more LaCie).
