Activity Forums VEGAS Pro Building a new PC for using Vegas 11…
  • Jeff Schroeder
    February 20, 2012 at 4:48 pm
    This all looks pretty good. If budget is a concern, I would go with a smaller SSD. All you have on it is System and Programs. One of mine at work is a 60GB it’s about 2/3 full. I would add 2x2TB drives for storage. Both my editing systems are rock solid. I use ASUS boards and video cards.
    Jeff
    Windows 7 64-bit, ASUS P6X58D, i7 960 3.20GHz, 24.0GB DDR3, 12TB connected storage
    http://www.narrowroadmedia.com
  • Steve Rhoden
    February 20, 2012 at 6:41 pm
    you guys have all the luck….lol
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    1-876-832-4956
  • Brad Miller
    February 20, 2012 at 10:50 pm
    I went with a 120 GB for $130 from Agility.
  • Mikhail Petrushin
    February 20, 2012 at 11:14 pm
    I see that many NVidia users have problems with Vegas 11.
    Actually, I have ATI/AMD video card (with last _release_ not beta drivers) and Vegas crashes rarely in my case so I don’t disable GPU usage.
    Also, look at this page. You’ll see that NVidia cards are better for rendering, bug ATI/AMD cards are better for playback. For me playback is more important as it allows me to have smooth preview while working with project. What about render? Well, I can render my project during nights. But right now I can’t use GPU with Mainconcept codec because of crashes during render (I hope it will be fixed in following builds). Also, some people say that encoding using CPU only gives better quality.
    P.S. I know that Intel/AMD and NVidia/ATI something like a religion. I know that NVidia with CUDA could be used in other programs as well. I have ATI and NVidia cards in my home computers. Both are fine.
  • Brad Miller
    February 21, 2012 at 1:42 am
    I based the video card on the recommendation of the videoguys.com. They recommended the GTX 550/570. I ended up getting the 560, though. I’ll cross my fingers.
  • Ken Mitchell
    February 21, 2012 at 1:11 pm
    You might want to put in a 2 or 3 drive raid for your playback files.
  • Bob Peterson
    February 21, 2012 at 4:46 pm
    I have an 80gig SSD (C:) which is fast when reading, and not so fast when writing. Whenever possible, I install my applications on a normal harddrive (D:) to avoid filling up the SSD. Ditto with documents and other user files. The SSD is used mainly by Windows.
  • Stephen Mann
    February 22, 2012 at 5:28 am
    [Ken Mitchell] “You might want to put in a 2 or 3 drive raid for your playback files.”
    Why? It won’t make any difference on the editing performance.
    BRAD – Go for a 1KW power Supply. In the future you will likely add more internal hard disk drives and a second display card, and a 750Watt supply just may not be enough.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Ken Mitchell
    February 22, 2012 at 5:52 am
    Why? Well of course a 3 drive/raid 5 would make a huge difference due to the fact that data loss due to drive failure would be minimized without reducing speed. We use them successfully all of the time.
  • Stephen Mann
    February 22, 2012 at 6:40 am
    As I said: “It won’t make any difference on the editing performance.”
    In twelve years I have lost project data due to hard disk failures exactly – zero times.
    I probably go through ten to twenty hard disks per year. Yes, I have had disk failures – just had one last week – but my projects are backed up daily.
    Steve Mann
    http://www.mmdv.com
