Activity Forums Adobe After Effects Building a house!
  • Building a house!
    Posted by Butch Golden on December 9, 2007 at 12:14 am
    It suks being new at this.
    I have 4 drawings, each depicting one of 4 sides of a rectangular house and want to assemble the front, back, and sides of it into a 3D object.
    Are there any tutorials on something this simple in AE? Where I start, work with the layers, etc. Short of that, a point to get me started? I can hunt and peck pretty wellif someone would give a boot in the right direction.
    Thanks in advance for any help.
    Butch Golden replied 18 years, 9 months ago 2 Members · 4 Replies
  • Mike Clasby
    December 9, 2007 at 4:34 am
    I like the script, createCylinder, sounds funny I know but if you just want four wall, a four sided cylinder is just four walls.
    https://www.nabscripts.com/Downloads/downloads_en_1.php?id=6
    Download “createCylinder”, put the .jsx in your Scripts Folder.
    There is also create cube (check the top box to use your layers, not create new layers).
    Then startup AE, and Select the 2D or 3D layers you want to put into a cylinder, Run>Script>createCylinder. In the Panel you use to Create (Creer) the Help is in English. The first parameter corresponds to the number of layers per level, four for four walls; the second to the Radius (rayon) of the cylinder, so make that half the width of the walls, 100 if the walls are 200 pixels wide. It creates a cylinder with a CONTROL layer (Null) to rotate/reposition the cylinder.
    You can swap the order of the wall just by moving them up or down in the layer stack.
    If you use create cube on six layers you’ll get a floor and ceiling but if they are wider than tall, you’ll get a gap so you’ll need to slide the floor up and the ceiling down, to do that, set a keyframe, disable the expression, then change the y until it fits. If no floor and ceiling, no problem.
    The script automatically makes the layers 3D for you.
  • Butch Golden
    December 9, 2007 at 2:33 pm
    I’ll have a look and a go at this after my 2nd cup.
    Are there any books / videos on the very basic mechanics of AE? I need to invest in my future.
  • Butch Golden
    December 9, 2007 at 5:14 pm
    Uh-oh
    I have to also understand and prepare the layers as I have only the one-dimentional drawings and haven’t done this before either. ()
    Got a road sign?
  • Butch Golden
    December 10, 2007 at 2:46 am
    Ok
    Figured out that I need four layers and will have to convert my png’s to psd’s as the ‘Photoshop Drawing’ layer is the (at least AFAICT) only way to get a still image on a new layer.
    Does this look like I’m getting anywhere or am I missing something.
    Thanks again for the help.
