Activity Forums Blackmagic Design Buidling a Box for
  • Buidling a Box for
    Posted by Shane Chadder on August 10, 2005 at 12:36 pm
    Hi
    Do you have any motherboards spec’d for your Multibridge PCI express product?
    I assume the faster the better and 64 bit windows support will all fall into place with Premiere Pro 2.0 in…sept, oct, nov, dec? Somebody ignore their NDA and tell us broadcasters trying to build suites.
    Matt Dowling replied 21 years ago 2 Members · 4 Replies
  • Shane Chadder
    August 10, 2005 at 12:37 pm
    Sorry, better subject heading.
  • Matt Dowling
    August 10, 2005 at 12:57 pm
    Hi Shane,
    It is still a little early for us to recommend motherboards and system setups. When we have completed our testing with various vendors we will post a full spec.
    Cheers,
    Regards,
    Matt
    Blackmagic Design
  • Shane Chadder
    August 10, 2005 at 5:27 pm
    Matt
    If I build one of your currently approved systems that have a couple of PCI express slots will it “likely” work?
    Will the Multibridge PCI express have any more “realtime” advantages over buying the the euqivalent “bits” ie multibridge, Decklink, HDLink?
  • Matt Dowling
    August 11, 2005 at 1:30 pm
    Hi Shane,
    I can’t give a 100% answer on that as we havent completed running tests. I believe it will certainly work for SD but as i said – havent finished HD testing.
    Cheers,
    Regards,
    Matt
    Blackmagic Design
