Activity Forums Boris FX Particle Illusion buglist: particleIllusion 3.0 for Windows
  • buglist: particleIllusion 3.0 for Windows
    Posted by Alan Lorence on September 25, 2007 at 5:43 pm
    This is a list of the bugs that were found in 3.0.1a of particleIllusion for Windows. These have been fixed in the 3.0.2 update which will be released shortly.
    If you know of a bug that is not on this list, please let us know immediately, or it won’t be fixed in 3.0.2.
    • Could crash at startup if “image” was used in preview window when last closed.
    • The DPI info was wrong in some image files written (PNG for instance).
    • Crashed when removing bg image from some projects
    • The “Where used” check for particle shapes did not work correctly for super emitters.
    • The “Use next key color” count didn’t reset in the preview window when the mouse was clicked, so colors would change every time.
    • The import position data “start at frame 0” dialog would always use “yes” so would always subtract 1 from the frame numbers.
    • During playback, toggling off bg movie display (with bg icon) would crash when playback was stopped.
    • The “separate fields” (deinterlace) options (in the layer “background images” dialog) would only work for images, not movies.
    Bob Cole replied 18 years, 11 months ago 3 Members · 2 Replies
  • Accountclosed
    September 26, 2007 at 7:44 am
    Thanks, Alan.
    That’s a thorough list reflecting what seems to be like some extensive hours of work at Wondertouch for the upcoming update. Added to that the handful of other improvements you’ve mentioned here and there at this forum,
    RE: 3.0.2: Numerically speaking it doesn’t give the impression of much of an upgrade — going from 3.0.1 to 3.0.2. Considering fixes and improvements, it sounds to me far more like at least a 3.2.0 upgrade.
    But then, hey, it’s your baby, not mine.
    You have the parental christening rights 🙂
  • Bob Cole
    September 28, 2007 at 12:17 am
    [Alan Lorence] “3.0.2 update which will be released shortly.”
    Alan, do you have an approximate date in mind for this update?
    Bob C
    MacPro 2 x 3GHz dualcore; 2 GB 667MHz
    Kona LHe
    Sony HDV Z1
    Sony HDV M25U
    HD-Connect MI
    Betacam UVW1800
    DVCPro AJ-D650
