Activity › Forums › Apple Final Cut Pro Legacy › bug….intel and hdv
  • bug….intel and hdv
    Posted by Alvaro Lanciai on November 28, 2007 at 10:29 am
    dear Friends,
    I discovered a bug testing my octocore intel with compressor.
    Unfortunately, encoding a file from hdv to m2v, an intel processor is 4 times slower than a non-intel processor,
    …only in this case…!
    An 1,30 minutes clip needs 12 minutes with a power book and the same file needs 45 minutes with an octocore 3.00 ghz…i tried other solutions swapping the disks (system and storage) from one machine to another but the problem remain in the same machine….
    I tried also with fps 6.0.2
    …awaiting for an apple resolution….
    MAC INTEL dual quadcore 3ghz
    4gb ram
    macos 10.4.11
    fcp 6.0.1
    Alvaro Lanciai replied 18 years, 10 months ago 4 Members · 10 Replies
  • 10 Replies
  • 13 Create COW Profile Image
    13
    November 28, 2007 at 7:35 pm
    I am betting that you are only using one of those cores to do the compressing.
    This video talks about compressor and how to enable it to use the full potential of your computer.
    https://www.pixelcorps.tv/macbreak89
  • Justin Ferar
    November 28, 2007 at 11:31 pm
    My tests came to the exact same conclusion. In fact I still have my dual 2.7 G5 (I edit on an octocore) just to do MPEG conversions.
    Leopard is supposed to fix all this but I haven’t got it yet.
    Alvo, you can look up my previous posts by viewing my profile and you’ll see what was said before.
    13
    November 28, 2007 at 11:40 pm
    [Justin Ferar] “Leopard is supposed to fix all this but I haven’t got it yet. “
    And where douse it say that?
  • Shane Ross
    November 28, 2007 at 11:55 pm
    [zrb123] “And where douse it say that?”
    Does…DOES. There is no U in there, unless you are putting out a fire.
    Shane
    Littlefrog Post
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.lfhd.net
    13
    November 29, 2007 at 12:40 am
    Sorry it has been a long day.
  • Justin Ferar
    November 29, 2007 at 12:59 am
    Heard it through the grapevine that Leopard better manages multi processors using Compressor.
    But don’t take it from me- wait for the early adopters to report.
  • Alvaro Lanciai
    November 29, 2007 at 4:05 pm
    dear zrb123,
    thank you for your prompt answer…I have to explain that the 8 cores are working all together from half to 3\4 of their capacity….I understand it just looking the green meters of my CPU MONITOR…and only when I use a magic bullet efx the processors are not optimized and i can see working only one processor a time….but i disabled magic bullet efx for this reason…
    I tried to work enabling the Qmaster function as seen on that video (thank you) but it does not affect the neverending rendering times…I’m currently trying to do that more exatcly…
    I think that the best solution will be another one : to capture the footage coding in APPLE INTERMEDIATE CODEC -best quality-….any other ideas…?
    hoping in Leopard features…..
    Alvo
    4gb ram
    macos 10.4.11
    fcp 6.0.1
    13
    November 29, 2007 at 4:08 pm
    I would go with ProRes over AIC.
  • Alvaro Lanciai
    dear Justin…
    thankyou for your answer…
    Yes I hope in lepoard, but in the meantime i’ve to finish my work coding and capturing with apple intermediate codec-best quality-…
    4gb ram
    macos 10.4.11
    fcp 6.0.1
  • Alvaro Lanciai
    November 29, 2007 at 4:11 pm
    aren’t the file coded with pro res, 3 times bigger than HDV or other coded with AIC…?
    4gb ram
    macos 10.4.11
    fcp 6.0.1
