Activity Forums Adobe After Effects Buggy leading settings in AE CS4
  • Buggy leading settings in AE CS4
    Posted by Ben Trahair on May 14, 2009 at 2:04 pm
    Wondering if anyone else has run into this – the leading settings in Adobe CS4 are markedly different to those in CS3 – For example, using a leading value of 0 with a point size of 30 on my text I can’t actually get two lines of text to touch each other or even overlap. The only way around this is to us a much bigger point value than I need and scale down the text – or split my text on to two separate text layers and manually adjust their position.
    Has anyone else run into this issue? I’m guessing its a bug because the leading settings in photoshop CS4 are absolutely fine – with a value of zero two lines of text perfectly overlap.
    http://www.bentrahair.com
    Ben Trahair replied 17 years, 4 months ago 2 Members · 2 Replies
  • David Hernandez
    May 14, 2009 at 2:57 pm
    Hmmm.. Good question. I will look into it.
  • Ben Trahair
    May 14, 2009 at 4:05 pm
    Ok.
    After further investigation it looks like this issue is isolated to one of our machines – another one with a clean install of CS4 is fine – the one in question had a previous installation of 6.5 and CS3 that were deactivated and removed. Possibly something corrupted along the way.
    Will try a re-install.
    Intel Mac 2 x 2.66 GHZ Dual Core
    4GB 667 Mhz DDR2 RAM
    Mac OSX 10.4.11
    AE CS4
