Activity › Forums › Boris FX Particle Illusion › Bug(?) report
  • Posted by Thomash Lee on October 1, 2005 at 9:49 am
    Deleting the library texture that using by library emitter will crash that library permanently. I suggest that system checks the texture usage and cease the deletion if the result is positive can save my regret…
    Thomash Lee replied 20 years, 12 months ago 2 Members · 2 Replies
  • Alan Lorence
    October 1, 2005 at 1:02 pm
    I’ll need more details on this crash — I’ve deleted library shapes that are being used in the library with no problems before. Perhaps you’ve found a special case? Please send as much detail as possible to wondertouch support.
    Alan.
    wondertouch
  • Thomash Lee
    October 1, 2005 at 1:36 pm
    To be exact, I deleted the shape in the “emitter properties in library”(right section) and caused the problem. I try again and this time I delete the shape in “emitter properties” of individual emitter (left section), and no error happened, the library emitter simply missed that texture in preview.
