Activity › Forums › AJA Video Systems › Bug With Kona Software 6.0?
  • Bug With Kona Software 6.0?
    Posted by Sean Oneil on August 21, 2008 at 12:27 am
    After capturing with FCP 6.0.4, my NTSC clips are seen as Upper-field first dominance. Not lower-field like it’s supposed to be.
    I only tried my usual Easy Setup “AJA KONA 3 – NTSC Apple ProRes 422.” Haven’t tried any others.
    I checked the Capture Preset for that Easy Setup. It is in fact set to bottom-field first like it’s supposed to be. But it’s not working out that way.
    Mark Maness replied 18 years ago 5 Members · 13 Replies
  • 13 Replies
  • Paul Provost
    August 21, 2008 at 4:15 am
    did you run the firmware updater after the 6.0 software install?
    Paul Provost
    http://www.postandbeam.tv
  • Sean Oneil
    August 21, 2008 at 5:43 am
    Yes.
  • Jeremy Garchow
    August 21, 2008 at 4:21 pm
    I’d imagine this is an FCP bug. You can change the field dom after the fact.
  • Sean Oneil
    August 21, 2008 at 5:56 pm
    [Jeremy Garchow] “I’d imagine this is an FCP bug.”
    It doesn’t happen with Kona 5.1 drivers.
    Sean
  • Paul Provost
    August 21, 2008 at 6:05 pm
    anybody tried 10bit ntsc yet?
    Paul Provost
  • Sean Oneil
    August 21, 2008 at 6:38 pm
    AJA support just got back to me. They confirmed the bug. It’s only with “that codec” (don’t know if that includes ProRes HQ as well) and it’ll be resolved with a 6.1 maintenance release. They do have kick-ass support. Imagine trying to bring an issue like this up with Apple.
    Sean
  • Jeremy Garchow
    August 21, 2008 at 6:47 pm
    Nice!
  • Sean Oneil
    August 21, 2008 at 8:40 pm
    Ugghh. Not so nice anymore. So I downgraded to 5.1 per their instructions. Now I get a kernel panic anytime I playback footage.
    I think I either need to downgrade my firmware somehow or go back to 6.0 and not use ProRes SQ.
    Sean
  • Jeremy Garchow
    August 21, 2008 at 8:52 pm
    Yes, you need to downagrade the firmware. You can do this with the Kona Firmware updater. You might have to install 6.0 again. I am pretty sure it’s in the manual or the release notes on how to do it. I know there’s specific instructions for it somewhere just for this very reason.
    Jeremy
  • Sean Oneil
    August 21, 2008 at 10:42 pm
    Thanks Jerermy. I found the fw downgrade instructions and everything’s now back to the way it was pre-6.0. Not sure why I updated in the first place as everything worked fine. I think the whole “AV Sync Issues Resolved” in the release notes had me a bit freaked out.
    Sean
