Activity Forums Adobe Premiere Pro Bug when switching between work spaces in CC?
  • Bug when switching between work spaces in CC?
    Posted by Steve Martin on August 28, 2013 at 12:13 am
    Maybe this is a bug or perhaps operator error…
    When I wrapped up my final content edit, I switched into the color correction workspace to begin grading. Once I completed the color work, I switched back to the editing workspace to watch the completed program. As I watched it, I noticed that some of the edits I thought I had made, were not there. It turned out that when I switched to color correction workspace, Premiere had switched to a different sequence. In this case, it was a draft sequence (one generation removed from the final). I had done all the color correction work to the wrong %^$#*&)*-ing! & sequence!
    I have since tested and my system does this every single time I switch to/from the Color Correction workspace.
    Thank goodness, Premiere now has a more robust paste attributes in CC that it did in CS6 – or it would have taken much linger to fix.
    Anybody else seen this? Is this a bug or a problem with my system.
    MacPro 8,2
    OS 10.8.4
    Premiere CC
    Steve
    Production is fun – but lets not forget: Nobody ever died on the video table!
    http://www.OmniNewMedia.com
    http://www.GreenSlateStudios.com
    Steve Martin replied 13 years ago 2 Members · 2 Replies
