bug when rendering screencast with text scroll + 2sec black screen at beginning
I recorded a screencast with the software “debut”. It is all fine when I check the file. Now when I import it to Sony Vegas Pro 13, everything is fine except when there is some text with scrolling. The bug appear on rendering and also in the preview in sony vegas.
The project and the original file have the same frame rate: 25 fps, and same rezolution: 1280×720
Here is a sample:
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
I also have another bug, as you can see on the same sample: It always add a 2 or 3 seconds black screen at the beginning. Searching for the last 2 days, I’m now desperate. Please help!
