Activity Forums VEGAS Pro Bug render with stabilization on vegas pro 12
  • Bug render with stabilization on vegas pro 12
    Posted by Lucas Pelus on June 10, 2015 at 1:25 pm
    Hello,
    I add the sony stabilization on a rush.
    On the preview it’s perfect. There is a zoom and there is no more tremblings…
    But when I render the project it’s like the stabilization is disable.
    However I’m sure it is activated on the rush…
    Any idea ?
    Lucas Pelus replied 11 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • Bob Peterson
    June 11, 2015 at 1:29 am
    Try redoing the render. This time be absolutely sure that it is activated before you do the render. I’m thinking that you were rushed, and perhaps all did not go as you expected. When I have used stabilization, it has always worked as expected.
  • Lucas Pelus
    June 11, 2015 at 12:27 pm
    Hello,
    Unfortunately I already tried many times.
    can you tell me what exactly you are doing when you use the stabilization ?
    4im sure on the preview it’s perfect and the render is like stabilisation disable…
  • Lucas Pelus
    June 18, 2015 at 12:46 pm
    I think i made some saving about stabilization settings and now it seems to work less.
    I remove et re install vegas but all the settings change (life the rendering, etc) still stays in vegas.
    Do you know where i could delete all i change ?
    Thanks !
  • Aaron Star
    June 18, 2015 at 7:24 pm
    When I have used that plugin, you have to apply the effect as a media effect, then render the result inside the plugin.
    You may try and apply the stabilization and render to the clip to new media file from another instance of vegas. Then use that stabilized clip. This keeps vegas from stabilizing clips from long media.
  • Lucas Pelus
    June 18, 2015 at 7:29 pm
    I’m not speaking very english so you mean :
    1. I open a new project, i add only my rush, i add the special effect “sony stabilization”, I apply the effect, i render the rush for example on mp4.
    Now I add this new stabilized file on my big project ?
  • Lucas Pelus
    June 18, 2015 at 9:46 pm
    Now I can’t even apply the stabilization as you can see, i can not change the settings and not apply too even if i check the stabilization on the top
  • Lucas Pelus
    June 25, 2015 at 1:07 pm
    I made it.
    Juste need to go in tools and video options.
    I do not have to use the shortcut in time line
    I think it’s not exactly the same
