Activity Forums Adobe After Effects Expressions bug in outPoint output
  • bug in outPoint output
    Posted by Yaniv Cahoua on June 17, 2019 at 7:56 am
    Hey everyone,
    I was getting a wrong outPoint value in my expression
    A=thisComp.layer(“Vibration Anim”);
    A.outPoint / thisComp.frameDuration;
    As a test, I made a simple text layer and whip picked the A variable to a layer in my comp.
    The inPoint will return the correct value but not the outpoint.
    I had to play and move a bit the outPoint to get it to return the right value….
    is this a known issue ?
    http://www.yanivcahoua.com
    Yaniv Cahoua replied 7 years, 3 months ago 2 Members · 2 Replies
  • Miguel De mendoza
    June 20, 2019 at 9:53 am
    In the graphic interface of After Effects, you will always see “one more frame” at the end of the layer. If you look at the exact frame where the layer ends, you will see that nothing appears in the viewer. However, outPoint refers to that last frame in which the layer is no longer visible. Therefore, if you want to know what is the last visible frame of the layer, you should subtract a frame in your expression:
    A=thisComp.layer("Vibration Anim");
    A.outPoint / thisComp.frameDuration - 1;
  • Yaniv Cahoua
    June 23, 2019 at 8:33 am
    thank you
    I am aware of that,
    I was getting a big gap in value.
    and it was clearly a bug when I played with the outpoint trimming it fixed it and I was getting accurate values
