Activity Forums Apple Final Cut Pro Legacy BUG: Decklink Drivers and FCP Pulldown Removal Problems
  • BUG: Decklink Drivers and FCP Pulldown Removal Problems
    Posted by Bizatch on April 16, 2006 at 11:43 pm
    I found a bug. Can other please verify?
    I shot a show on the Panasonic HVX200 in DVCPRO50 24Pa (2:3:3:2 advanced pulldown cadance). Before I purchased the Decklink HD Pro (Single Link), I was able to import these clips into Final Cut Pro 5.0.4 through P2 Import. I was then able to go to Tools > Remove Advanced Pulldown without any problems. My system, Quicktime, etc were all completely up to date as I just did a clean install of the system.
    I then purchased the Decklink HD Pro (Single Link) and installed the card and installed the drivers. Any NEW clips that I imported still had the same exact properties (according to FCP), but I could no longer do the Remove Advanced Pulldown on the new clips. FCP would give a warning that the clips were not either DV, DVCPRO or DVCPRO50, even though I had checked the clip properties, and they were DVCPRO50.
    Then, I uninstalled the Decklink drivers and imported clips again. I could remove the pulldown from these clips.
    Adam
    Bizatch replied 20 years, 5 months ago 2 Members · 2 Replies
  • Walter Biscardi
    April 17, 2006 at 11:16 am
    [Adam] “I found a bug. Can other please verify?”
    Have you posted this in the BlackMagic forum?
    Did you contact BlackMagic support?
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Bizatch
    April 17, 2006 at 3:33 pm
    Yes and yes. 🙂
    Adam
