Activity Forums Blackmagic Design BUG: Decklink Drivers and FCP Pulldown Removal Problems
  • BUG: Decklink Drivers and FCP Pulldown Removal Problems
    Posted by Bizatch on April 16, 2006 at 10:36 pm
    I found a bug. Can other please verify?
    I shot a show on the Panasonic HVX200 in DVCPRO50 24Pa (2:3:3:2 advanced pulldown cadance). Before I purchased the Decklink HD Pro (Single Link), I was able to import these clips into Final Cut Pro 5.0.4 through P2 Import. I was then able to go to Tools > Remove Advanced Pulldown without any problems. My system, Quicktime, etc were all completely up to date as I just did a clean install of the system.
    I then purchased the Decklink HD Pro (Single Link) and installed the card and installed the drivers. Any NEW clips that I imported still had the same exact properties (according to FCP), but I could no longer do the Remove Advanced Pulldown on the new clips. FCP would give a warning that the clips were not either DV, DVCPRO or DVCPRO50, even though I had checked the clip properties, and they were DVCPRO50.
    Then, I uninstalled the Decklink drivers and imported clips again. I could remove the pulldown from these clips.
    Adam
    Bizatch replied 20 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
