Activity Forums Adobe After Effects Expressions [SOLVED] Color value doesn't work with if else statement
  • [SOLVED] Color value doesn't work with if else statement
    Posted by Remi Monedi on September 13, 2020 at 1:33 pm
    Hi!
    I tried to do a simple thing and I don’t understand why it is not working…
    I have a color control set to white ( [1,1,1,1] ) and a slider which should display “999” when the color is white. I made this expression :
    if (effect(“Color Control”)(“Color”)[0] == [1,1,1,1]) 999
    else 0
    And it doesn’t work! I tried in rgb, in hex, i tried to change the [1,1,1,1] to another white Color Control, nothing! Am I missing something here?
    Dan Ebberts
    replied 6 years ago
    2 Members · 2 Replies
  • Remi Monedi
    September 13, 2020 at 1:40 pm
    Ok. After looking some more at some code found on this forum, I found I just had to add [0] after the color value. Then to work properly, the expression should be :
    if (effect(“Color Control”)(“Color”)[0] == [1,1,1,1][0]) 999
    else 0
    Sorry for the double post…
  • Dan Ebberts
    September 13, 2020 at 2:13 pm
    <div>If you do that, you’re only checking the red channel. Maybe something like this:</div>
    c = effect("Color Control")("Color").value;
    if (c[0] == 1 && c[1] == 1 && c[2] == 1)
    999
    else
    0
    or this:
    white = [1,1,1,1];
    if (JSON.stringify(c) == JSON.stringify(white))
    999
    else
    0
    Dan
