Activity › Forums › Adobe Premiere Pro › (BUG) CC 2020 dynamic link AE comp playback discolouration in PP
  • (BUG) CC 2020 dynamic link AE comp playback discolouration in PP
    Posted by Matt Gilchrist on January 9, 2020 at 2:11 pm
    Hi all
    First post here, so thanks for having me!
    I’ve just upgraded to CC2020 and predictably am having a few teething problems.
    After Effects compositions in my Premiere Pro sequence appear discoloured (sort of inverted/distorted) in the Program monitor only when playing back and scrubbing through the timeline. Examples below:
    1. No playback – program monitor appears as expected.
    2. Playing back – distorted colours.
    Other info:
    After the video has rendered the colour is back to normal, so the bug is isolated to playback.
    The issue is present in all projects.
    Drivers are all up to date.
    I’ve been working on identical projects for the past 2 years with no similar issues, the only variable is the update to CC2020.
    Spec:
    • Windows 10
    • i7 3.6GHz
    • 16gb RAM
    • 1TB SSD
    • AMD Radeon R7 450
    Has anyone else had this issue and/or has any idea what might be causing it?
    Thanks in advance
    Matt
    Matt Gilchrist replied 6 years, 8 months ago 2 Members · 2 Replies
  • Chris Wright
    January 10, 2020 at 5:13 am
    is high quality playback enabled?
  • Matt Gilchrist
    January 10, 2020 at 8:43 am
    Thank you Chris – that’s done the trick! Much appreciated.
