Activity › Forums › Compression Techniques › buffer uderflow while joining vob files
  • buffer uderflow while joining vob files
    Posted by Bimal Kumar on August 13, 2014 at 9:23 am
    hello
    I am getting following error while trying to join 4 vob files
    [vob @ 0x1c00e920] packet too large, ignoring buffer limits to mux it
    [vob @ 0x1c00e920] buffer underflow st=1 bufi=10093 size=19311
    [vob @ 0x1c00e920] buffer underflow st=1 bufi=12113 size=19311
    [vob @ 0x1c00e920] buffer underflow st=1 bufi=14133 size=19311
    this is the command i am using
    system("ffmpeg -f concat -i list.txt -c:v copy -c:a copy -bufsize 1835k -f vob joined.mpg");
    mediainfo on one of the vob file gives this output
    General
    Complete name : VTS_02_1.VOB
    Format : MPEG-PS
    File size : 1 000 MiB
    Duration : 39mn 59s
    Overall bit rate mode : Variable
    Overall bit rate : 3 496 Kbps
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Default
    Format settings, GOP : M=3, N=15
    Duration : 39mn 59s
    Bit rate mode : Variable
    Bit rate : 2 979 Kbps
    Maximum bit rate : 3 500 Kbps
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate : 29.970 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Bottom Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.288
    Time code of first frame : 00:00:00:00
    Time code source : Group of pictures header
    Stream size : 852 MiB (85%)
    Color primaries : BT.470 System M
    Transfer characteristics : BT.470 System M
    Matrix coefficients : BT.601
    Audio
    ID : 189 (0xBD)-128 (0x80)
    Format : AC-3
    Format/Info : Audio Coding 3
    Mode extension : CM (complete main)
    Format settings, Endianness : Big
    Muxing mode : DVD-Video
    Duration : 39mn 58s
    Bit rate mode : Constant
    Bit rate : 448 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 128 MiB (13%)
    Menu
    ffmpeg version
    ffmpeg version N-63147-g8b96f31 Copyright (c) 2000-2014 the FFmpeg developers
    Need help in joining the files.
    Bimal Kumar replied 12 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
