Activity › Forums › Adobe After Effects › Bubbles..where can I find a Bubble effect
Posted by Scotty Pupkin on September 19, 2006 at 6:08 pmHi
I need bubbles.
I’m using a still image of a kid blowing bubbles and I want to make it come to life….is there a plug in that can do this?
thanks
Scotty Pupkin replied 20 years ago 5 Members · 6 Replies -
Scotty Pupkin
September 19, 2006 at 6:11 pmI have an edit bay full of people so I’m sorry about being short w/ my post…
I simply want to apply bubles on top of the image , coming out of the “mouth area.”
thanks
John Cuevas
September 19, 2006 at 6:13 pm -
Tom Hepburn
September 19, 2006 at 6:40 pmOne other thing to point out is that a realistic bubble has a significant amount of relection on it. If possible you may consider locating a friend/place with 3D capabilities. Just a suggestions.
T
Justin Productions
September 19, 2006 at 6:48 pmThere’s the Foam Effect, that you can get here.
And there’s Trapcode Particular.
Hope that helped.
Justin Productions
Tangerin01@hotmail.com
Adobe After Effects 6.5 Professional -
Roland R. kahlenberg
September 19, 2006 at 7:12 pm[Levels] “One other thing to point out is that a realistic bubble has a significant amount of relection on it. If possible you may consider locating a friend/place with 3D capabilities. Just a suggestions.”
Foam does include a reflection parameter, great physics. Works great, renders fast. The only thing I hate about it is that it doesn’t handle time sampling of the custome bubbles very well. It uses a simple (dumb) time sample of the custom bubble (any layer in the same comp); to the extent that all the particles look alike, except for shape and rotational values. But for bubbles, they’ll work.
Cheers
Roland Kahlenberg
broadcastGEMs
customizable animated backdrops with Adobe After Effects project files -
Scotty Pupkin
September 20, 2006 at 6:14 amThank you ALL! I can’t tell you how much I appreciate your feedback!
I used the Foam effect in particular and the client LOVVVVVED it! Looks great!
Again….BIG THANKS!
