Activity Forums Panasonic Cameras BT LH900
  • Posted by Jim on June 6, 2005 at 2:34 pm
    I am looking at the LH900 to be my new field monitor to take me from Betacam (D30) to the HVX200.
    The specs on the 900 say it will take a composite signal (ok for my Betacam), and that there is an SDI HD in. It also mentions a component in, is that also an HD self sensing input? Will I be able to monitor a HD output from a HVX200 on a LH900 (without a SDI converter)?
    Please help clarify the input capability of the LH900 and the output capability of the HVX200.
    Jim Cunningham
    cunninghamprod@sbcglobal.net
    Toke replied 21 years, 2 months ago 3 Members · 3 Replies
  • Mike Bergeron
    June 7, 2005 at 1:45 pm
    Jim,
    Yes the BT LH900 will accept SDI, Composite, Component HD (self sensing 720p, 1080p, 1080i), Component SD, HD SDI (self sensing, 720p, 1080p, 1080i). The component HD will be perfect for the HVX200.
    And By the way the same input capabilities will be true for the BT-LH1700 which will be hitting the street this Summer if you want something larger.
    Mike Bergeron
    Camera Engineer
    Panasonic Broadcast
  • Jim
    June 7, 2005 at 2:06 pm
    Mike:
    Thanks for the info. the LH900 today(for the field), perhaps the 1700 by the fall(for the edit suite).
    Jim Cunningham
  • Toke
    June 16, 2005 at 7:45 am
    Anything with 16:9 AR?
    I’d feel a bit funny to spend top dollars to a brand new hd monitor that has 4:3 AR…
