Activity Forums Adobe After Effects BrushStroke-Path (Illustrator) to import in AE
  • BrushStroke-Path (Illustrator) to import in AE
    Posted by Mika1976 on November 16, 2007 at 12:45 pm
    Hi there,
    i want to outline a stroke im Illustrator to import the path into after effects… it’s a stroke with a caligrahic brush… when i select the stroke, go to object>Path>Outline stroke it does not work! ??? it creates an outline, but it’s much smaller and there is no brushstyle applied…
    what a mystery 😉
    is there a trick?
    best wishes, michael
    Mika1976 replied 18 years, 10 months ago 18,780 Members · 1 Reply
  • Mika1976
    November 17, 2007 at 3:56 pm
    yes thanks… this tutorial is great… but:
    in fact i’ve had a problem in illustrator… if i want to create an outline from a artistic brush stroke, it doesn’t work…
    mmmh…
    cheers, mika
