Activity Forums Maxon Cinema 4D Brushed metal texture
  • Brushed metal texture
    Posted by Carlos Angeli on April 7, 2012 at 10:49 am
    I’m working on a disk brake. Modelling is finished, and I’m working on lighting and textures right now.
    I wanted to achieve a realistic radial metal texture. I got close by using a luma shader in the luminance channel for the inside of the disc. Also I’m using HDRI and a few omni lights for reflections only.
    However I’m lost for the outside part. The radial/elliptic pattern is similar to what I’m aiming for https://brakedisc.reaindia.com/productimg/504_588.jpg
    Any ideas on how to achieve this?
    Thanks.
    Andrew Larson replied 14 years, 4 months ago 4 Members · 6 Replies
  • Randy Johnson
    April 7, 2012 at 12:35 pm
    I would start by getting the material clean and the way I like it. Then Create a greyscale bitmap in PS with the rotation pattern and layer that into most of the channels… like as a mask on the reflection, specular.
    /Randy
  • Carlos Angeli
    April 9, 2012 at 5:13 pm
    Thanks Randy. I was trying that, but also wondered if there’s a way to achieve it using lumas or some other shader.
  • Brian Jones
    April 9, 2012 at 7:47 pm
    the only way I could think of to get that repeating circle pattern would be to use the spline shader with a spline made for the job – which could be done with the built-in tools, a circle spline in a radial cloner for starts.
  • Carlos Angeli
    April 9, 2012 at 9:55 pm
    Hi Brian,
    I’m not familiarized with the spline shader. I’ll look into it.
    Thanks for the tip
  • Brian Jones
    April 10, 2012 at 1:12 am
    be careful to read to the bottom of the main page of the help on it. It helps a lot to keep the spline to 100×100 in size and absolutely you have to have the axis like in Illustrator, it should be at the lower left of spline not centered.
  • Andrew Larson
    May 2, 2012 at 2:57 pm
    ok here is a file with the Nukei Shader I think it will do what your looking for.
    4067_diskbreak.c4d.zip
    Blur the lines between work and play.
    Andrew Larson
