Activity › Forums › Adobe After Effects › Brush Strokes Effect
  • Brush Strokes Effect
    Posted by Jonathan Alexander on January 19, 2007 at 11:14 pm
    I looked it up in the forum and found nothing with this particular thing. Anyways, is there a way to get the brush strokes effect to not animate? I like the look, but it is annoying how there is no control for the wiggling of it on each frame. Any ideas? And I am using it in an adjustment layer, so I can’t just timemap it to one keyframe, it won’t let me do that. I haven animation underneath, I just want the crush strokes to not move, thanks for any help!
    Jonathan Alexander replied 19 years, 8 months ago 3 Members · 4 Replies
  • Mike Clasby
    January 19, 2007 at 11:56 pm
    Can you isolate (with the eyeballs) the layers) that take the Brush strokes effect, then Composition>Save Frame As>File, then use the still to replace the layer(s)?
  • Jonathan Alexander
    January 20, 2007 at 12:31 am
    Well basically the effect is on an adjustment layer and there is a lot of moving parts going on below that adjustment layer. I mean take roughen edges for example, I want something like that. I mean if I add roughen edges to an adjustment layer it will effect everything below, but it won’t wiggle around and animate. You know what I mean? I’m not being clear.
  • Mylenium
    January 20, 2007 at 4:15 pm
    I think the Brush effect is meant to re-seed at every frame. If you really need something like that, you have to build it manually and perhaps apply it as a Luma Matte or something like that.
    Mylenium
    [Pour Myl
    January 22, 2007 at 5:43 pm
    Wish they had a random seed attribute that I could set to 0!
