Activity › Forums › Maxon Cinema 4D › brush proxy
brush proxy
Posted by Varadha Rajan on August 12, 2009 at 11:11 amif any option in c4d body paint brush proxy? pls help
Adam Trachtenberg replied 17 years, 1 month ago 2 Members · 6 Replies -
Varadha Rajan
August 13, 2009 at 9:32 amif i am painting in c4d bodypaint the brush wil appere pixalated i con t do that clearly how can i slove this? if there any proxy mode or best mode like that? can u help me
Adam Trachtenberg
August 13, 2009 at 2:54 pmIf your brush strokes are pixelated it’s because the texture you’re painting on is too small, or else there’s something wrong with your UVs.
Varadha Rajan
August 14, 2009 at 8:55 amya thats my mesh problem my mesh scale is to high now i corrcect it and also (i put my uv is 1k res so), thanks lot,,
Varadha Rajan
August 18, 2009 at 2:59 amI loaded a character which is 6ft height. Actually I have work with cms as units. When iam converting the units the char haven’t changed to 183 cms. The char got converted to 6 cms. How to convert with proportion between units?
Adam Trachtenberg
August 19, 2009 at 1:44 pmYou’ll have to do it manually. You can use the coordinates manager. Type *30.48 after the existing dimension in the size field for the x,y, and z dimensions. So for height, it would look like: 6cm*30.48
