Activity › Forums › Storage & Archiving › BRU PE Restore fail
  • BRU PE Restore fail
    Posted by Kevin Francis on August 4, 2022 at 10:35 pm
    Hi guys, we used BRU PE briefly in 2012 right before we switched to LTFS and I just had a request for archival footage that we had backed up in that environment. I’ve still got a workstation connected to an LTO-5 tape drive for just this purpose and it has been working up until now. I’m getting this error message when I try to restore the files:
    >>> /private/etc/sudoers.d/BRUExemptions: Alias “BRU_CMDS” already defined near line 2 <<<
    sudo: parse error in /private/etc/sudoers.d/BRUExemptions near line 2
    sudo: no valid sudoers sources found, quitting
    sudo: unable to initialize policy plugin
    Anyone got any ideas?
    Kevin
    Kevin Francis replied 4 years, 1 month ago 3 Members · 4 Replies
  • Neil Sadwelkar
    August 5, 2022 at 1:24 am
    Which version of Bru and which version of MacOS are you on?
  • Kevin Francis
    August 5, 2022 at 1:47 am
    Hi Neil,
    BRU PE 3.2.6 80 and MacOS 10.13.6
    Thanks.
  • Tim Jones
    August 6, 2022 at 3:05 pm
    There are two possible causes for this:
    A doubling of the inclusion of the sudoers.d folder –
    1. Open a Terminal
    2. Execute:sudo -s
      visudo
    3. Using the arrow/cursor keys, scroll to the bottom of the file
    4. With the cursor position on the line that reads #includedir /etc/sudoers.d type “dd” (two d’s)
    5. That line will disappear
    6. To save the file and exit the editor type “:wq” and hit enter
    The second is because the BRU_CMDS entry has been added multiple times to the /etc/sudoers file directly –
    1. Open a Terminal
    2. Execute:sudo -s
      visudo
    4. Find a line that reads:
      Cmnd_Alias BRU_CMDS =
    5. You should see 1 or more duplicates of that line
    6. Using “dd” as above, delete all but one of the entries
    7. To save the file and exit the editor type “:wq” and hit enter
  • Kevin Francis
    August 9, 2022 at 9:15 pm
    Thanks Tim. When I enter “sudo -s” I get this in return:
    Echo:~ echo$ sudo -s
    Echo:~ echo$ visudo
    visudo: /etc/sudoers: Permission denied
    One other thought. Does BRU PE 3.2.6 Build 80 support APFS?
    Thanks for your help.
    Kevin
