Activity Forums Storage & Archiving BRU PE: Power failure during archive process
  • BRU PE: Power failure during archive process
    Posted by Lasse Lyhne abild on March 6, 2017 at 11:52 am
    Hi all,
    Unfortunately I was in the middle of archiving, when I had power failure, and everything stopped. ☹
    The archive job was set up as an append job, and spanned three tapes. When I restarted BRU PE the Archive (called Archive Feb 2017) showed a symbol stating it spanned over three tapes, but when looking in the archive, it only showed the catalogues made before, and one new one called “No Archive Catalog Found”.
    Is there anything I can do about this, can the append be done again, so I don’t waste tapes, or should I simply start a new job, overwriting the tapes??
    /Lasse
    Head of Postproduction @ Nerd Productions, Denmark
    We do
    Videoproduction in Copenhagen
    Corporate videos
    and whatever our imagination tells us!
    Dean Tyson replied 9 years, 5 months ago 3 Members · 2 Replies
  • Tim Jones
    March 6, 2017 at 5:26 pm
    Unfortunately, a power failure is the one situation that we can’t sort out automagically. While BRU can restore any files that were written onto the tape up to the point of the failure (unlike LTFS where the take is now completely a brick), the tape is left in a state where the end of the data markers that would normally be written are not there for additional write operations to find and start from.
    As for BRU PE and the Catalog not found, that’s because the failure occurred before the job finished, so the catalog is still in the temporary state and hasn’t been finalized and added to the Catalogs folder.
    Please open a ticket at support.bru.com and let’s see if the guys can help you out with recovering the catalog for that failed job.
    Tim
    Tim Jones
    CTO – TOLIS Group, Inc.
    https://www.tolisgroup.com
    BRU … because it’s the RESTORE that matters!
  • Dean Tyson
    April 5, 2017 at 2:28 pm
    I know this was a while back, but if it were me, I would just redo the whole archive over.
    I have had to do this a few times in the past because BRU PE just froze up, or for some or other reason.
    Just safer to redo the archive and make sure the verify is completed 100%!
    Good luck.
