Activity Forums Storage & Archiving BRU PE no longer launching (mac)
  • BRU PE no longer launching (mac)
    Posted by James Spicer on April 24, 2017 at 5:41 am
    Hi all,
    I have inherited the use of BRU PE and it will no longer launch.
    The software asks for an authentication login which I enter and then the app does not launch. It’s like the window is off screen… I have no idea.
    Any trouble shooting steps I can try? I have restarted the machine twice.
    Tim Jones replied 9 years, 5 months ago 4 Members · 4 Replies
  • Sam Lee
    April 24, 2017 at 6:23 am
    Not sure what BRU version you’re using, but if it’s the latest build, then…
    BRU 3.1.23.3657 has serious problem in authentication. I have to type in the pw 3-5 times before it finally worked. Very annoying for over a month now. This is on OSX El Capitan.
    3.1.20 .278 doesn’t have this issue.
  • James Spicer
    April 24, 2017 at 6:36 am
    Yeah I’m not totally sure how to find out the BRU PE version without being able to launch it. The “about BRU PE” option is greyed out.. It is definitely a few years old.
    From the same Applications/BRU PE folder, BRU PE Import Tool, BRUSetta Stone Import Tool and BruTALK all launch once authenticated.
    BRU PE Import Tool = Version 3.1.19, build 237
    I have opened, authenticated and quit the application about 30 times.
  • James Vorley
    April 24, 2017 at 11:05 am
    Are you running headless and VNCing in?
    If so try plugging in a monitor.
    I’ve had stuff like this happen when running headless and connecting/disconnecting a monitor.
  • Tim Jones
    April 25, 2017 at 4:59 pm
    Force Quit
    Right Click the App in Finder
    CMD-I to get info
    Additionally, could the BRU UI have been launched on a secondary screen the last time it successfully launched?
    You can try removing the preferences file
    [code]rm /Library/Application\ Support/BRU\ PE/etc/com.tolisgroup.bru-pe[/code]
    Tim
    Tim Jones
    CTO – TOLIS Group, Inc.
    https://www.tolisgroup.com
    BRU … because it’s the RESTORE that matters!
