Activity Forums Storage & Archiving BRU PE Import tool can’t read multiples tapes
  • BRU PE Import tool can’t read multiples tapes
    Posted by Daniel Davila on September 15, 2014 at 3:37 pm
    I have a tape set that I need to catalog. When doing the import, each time it asks a new tape, first it says it’s not part of the set, I re insert it and goes on asking the next tape, and again the same problem. When it ‘s done with the last tape and re-inserts it, it finishes the process without creating the dataset saying it’s a “empty tape”! Any ideas?
    OSX 10.9.4 + BRU import tool 3.0.1
    Daniel Davila replied 12 years ago 2 Members · 4 Replies
  • Tim Jones
    September 15, 2014 at 4:34 pm
    I’d start by opening a ticket at https://support.bru.com.
    The way the import tool works is very dependent on HOW the original tapes were created – is it a single archive that spans multiple tapes? Is it multiple archives on a single tape? Is it multiple archives on multiple tapes? These scenarios are what the two options are for in the UI.
    If neither of those is working, there’s something odd with the tapes that we need input on as it’s probably a corner case that we didn’t think about. Once we have the info for your tape(s) layout, the Import Tool is updated to take that scenario into account.
    Tim
    Tim Jones
    CTO – TOLIS Group, Inc.
    https://www.productionbackup.com
    BRU … because it’s the RESTORE that matters!
  • Daniel Davila
    September 15, 2014 at 8:04 pm
    Hello Tim
    Thanks for the answer. We have the BRU system about three years and this the first issue we have had, so we don’t have a support contract active.
    The scenario is multiple archives on multiples tapes. Basically we started a tape set and we have made several new backups on that tape set over the time using the append option.
    Maybe the import tool gets only the first Archive ID?
    Thanks, Daniel
  • Tim Jones
    September 16, 2014 at 3:18 pm
    Please open a support ticket on this anyway. Select Demo as the serial number and mention that I told you to open the ticket in the description. This falls upper a potential restore problem and the engineering team takes those VERY seriously.
    Tim
    Tim Jones
  • Daniel Davila
    September 16, 2014 at 3:43 pm
    Ok, thank you Tim, I’m on it.
    Greetings, Daniel
