Activity Forums Apple Final Cut Pro Legacy browser utilities
  • browser utilities
    Posted by Gary Anderson on April 17, 2009 at 11:11 pm
    I’m setting up an archive library with FCP.
    How can I export the browser window as a document?
    I’ve tried the export batch list function, and the columns disappear into a block of merged text. Is it possible to maintain the separate columns of description and time code?
    Andreas Kiel replied 17 years, 5 months ago 3 Members · 2 Replies
  • Josh Olenslager
    April 18, 2009 at 1:07 am
    Gary,
    Open your exported batch list in excel. Select “all” to highlight your text and go to the “DATA” menu in the task bar. Next select the “Text to Columns” function. Once the window opens choose “delimited.” A window will open that allows you to select something to recognize as a column break character (probably “space” in your particular case). Select one of the options, and Excel should separate your block of text into columns.
    Hope this helps!
    Josh
    Digital Media, Thought Equity Motion
  • Andreas Kiel
    April 18, 2009 at 9:45 am
    The Batch List is already “tab delimited” you don’t have to anything. Just import as “tab delimited” file.
    Andreas
    Spherico
    https://www.spherico.com/filmtools
