Activity Forums Apple Final Cut Pro Legacy browser says Advanced pulldown didn’t take: try cinema tools?
  • browser says Advanced pulldown didn’t take: try cinema tools?
    Posted by Vince Waldron on February 13, 2007 at 8:04 pm
    I’m in the midst of capturing many hours of interview footage shot in 24PA on a DVX100a. Although I always use the advanced pulldown capture setting, my results are inconsistent at best. According to FCP5’s browser, some of my captured clips are 23.xx fps while others are still 29.xx fps.
    1) Can I trust the accuracy of the info I see in the FCP browser with regard to the frame rate of my captured clips?
    If so,
    2) Should I now go back and try to recapture the clips that are listed as being 29.xx fps? Or would I be better off using Cinema Tools, which I understand can remove the pulldown from an already captured clip. One factor in my reluctance to re-capture is because there are occassional TC breaks in my footage that I often have trouble removing pulldown on the fly.
    Vince Waldron replied 19 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
