Activity › Forums › Apple Final Cut Pro Legacy › Browser menu doesn’t scroll properly/issues with log and capture.
  • Browser menu doesn’t scroll properly/issues with log and capture.
    Posted by Michael Garber on July 16, 2005 at 7:50 pm
    Hi All,
    Well here’s a weird one. When I add clips or bins to the browser menu (say 50 or so, enough to cause the scroll bar to come on), it doesn’t always scroll properly. Sometimes, the scroll bar goes away and it acts like clips below the bottom of the screen aren’t there. Can’t even use my scroll button on the mouse. Only thing that makes it go away is a reload of FCP.
    Anyone else found this bug?
    Also have some issues with log and capture – just the functionality isn’t the same as the old. And frankly I’m not thrilled with it. The way it used to be was that the description would auto-increment after each “log.” That doesn’t seem to be the case anymore. Also,, the shot/take and angle fields don’t stick around unless you hit the check mark. Again, something that I used a lot in 4/4.5.
    Stats:
    FCP 5.02, Kona, Io, (both latest drivers) G5 dual 2.5 w/ 8GB RAM.
    Michael
    Michael Garber replied 21 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
