Activity Forums DaVinci Resolve browse not seeing silent clips
  • browse not seeing silent clips
    Posted by Michael Stirling on December 6, 2010 at 12:09 pm
    hi,
    I am trying load a folder of clips that have been given that were media managed in FCP (1080p PRes 422) and the browse will only see some of the clips.
    the clips Resolve can see have video and audio, the ones it can’t are silent and all have -v suffix to the file name.
    Any thoughts of what is happening and how to solve it other than asking the editor to do it again?
    thanks
    mike
    Michael Stirling replied 15 years, 6 months ago 3 Members · 5 Replies
  • Kevin Cannon
    December 6, 2010 at 5:14 pm
    They have -v at the end because they were created by the media manager function in FCP, right?
    The last time I used that function, I had to individually add the .mov extension to each of those clips in the finder, which I guess the media manager does not do. Once I did that, Resolve recognized them all.
    There’s probably a clever way to use automator or such to add the extension, but it wasn’t immediately apparent to me.
  • Ola Haldor voll
    December 6, 2010 at 11:00 pm
    Automator could do the job quite fast. I don’t know the exact file name, but here’s what I’d do..
    EDIT!! I just remembered that if you select FOLDER instead of FILES in the first part of the workflow/app made with Automator, you can select a folder instead of each individual file with the “-v” in it. Makes it even easier to use!
  • Kevin Cannon
    December 7, 2010 at 4:16 am
    Good solution, but if you replace the -v in the filename, you wouldn’t be able to reconnect in FCP to Resolve-rendered media based on original filenames. Perhaps this?:
  • Ola Haldor voll
    December 7, 2010 at 3:13 pm
    Of course. I just didn’t understand what all the fuzz was about since I’ve never had this problem myself, but I see you got my idea. 🙂
    Good luck and happy automating.
  • Michael Stirling
    December 7, 2010 at 3:28 pm
    Hi
    Thank you all for this – works like a charm
    Mike
