Activity Forums Apple Final Cut Pro Legacy Broswer window cache
  • Broswer window cache
    Posted by The Hps on June 21, 2007 at 7:00 pm
    I’m doing some basic logging in the browser window, adding text to the description colum, etc.
    If I right click in that field, I get a list of all the previous descritions I’ve entered there. How to I delete those to get a clean slate? With a couble of hundred listings now, its pretty much useless.
    The Hps replied 19 years, 3 months ago 2 Members · 4 Replies
  • Russell Lasson
    June 21, 2007 at 7:20 pm
    I’m guessing you’re editing the Reel information?
    If so, that information is based on the clips you have in the browser, not a cache. So if you right click, it will show you all of the options for all of the clips in your project.
    If you start to group clips that you want to have the same name, then you can select all of the clips at once, right click and change all of the fields of the selected clips to go to whatever you select.
    -Russ
  • The Hps
    June 21, 2007 at 7:55 pm
    I think we’re talking about the same thing…close.
    I’m actually editing some of the Log Note and Description fields in the Browser. For things like Reel and/or Good columns, its great to be able to right-click and choose from the handful or so options that come up as a shortcut based on all the info already in that column.
    But for things like Log Note and Descrpition, every single one of those is going to be different. So like right now in Log Note if I right click, I get 100 options. How do I zero the right click menu so that I don’t have 1000 things in it by the time I’m done?
  • Russell Lasson
    June 21, 2007 at 8:13 pm
    I think that the pulldown menu is based on the other clips in the project, not cache.
    Here’s how you can tell:
    Close your project, create a new one and import one clip. Now right clip on the field that you’re trying to modify and see what shows up.
    -Russ
  • The Hps
    June 21, 2007 at 8:19 pm
    I see what you are saying. I’ll have to do that little experiment to find out for sure. Stay tuned. Thanks!
