Activity › Forums › Broadcasting › Brodcast – the whole picture is not seen
  • Brodcast – the whole picture is not seen
    Posted by Gašper Gaberšček on November 17, 2012 at 12:55 pm
    Hello.
    I am new to this forums and right of the bat I would need some help understanding some things regarding brodcasting.
    I was asked to make a 7s comercials for a company. Firstly they were ment to be web videos, but later, the company decided to brodcast them on our national TV stations.
    The TV station sent me this preferences:
    MPEG-2 Program Stream
    625/50 PAL Interlaced
    50Mbps CBR I frame only
    Profile: 422P@Main Level Colour Sampling: 4:2:2, 8 bit
    Video Size: 720 x 576 (608 inc VBI)
    Aspect Ratio 16:9
    Field: Upper field first (odd)
    MPEG Audio Layer-2
    Bitrate: 384kbps
    Sample Rate: 48khz Stereo
    To get you through my workflow (I am using Adobe Production Premium cs5):
    1. I created an animation in After Effects on a Full HD composition (1920×1080, 25fps, Square pixels), which worked out fine for web (YT).
    2. When asked to make the comercial for tv (PAL) I created a new composition (PAL D1/DV Widescreen Square pixels, 25fps and put the FULL HD composition into this one. I exported this composition Lossless out of AE and put it in Adobe Media encoder.
    3. In AME i rendered the loosless .avi in MPEG2 format, Upper field first, Pixel aspect ratio Widescreen 16:9 (1,459), that gave me an output of 720×576.
    4. The TV stations confirmed the ads and they went on to brodcast.
    Now this is where a problem occured. When i saw the commercial, the left and right side of the picture were croped, and some immportant parts of the text in the commercial was missing.
    As I found out, the missing picture is the difference between 720px and 625px.
    So I hope you can help me with this one. How can I export to get the whole picture on screen?
    Thank you in advance.
    Sareesh Sudhakaran replied 13 years, 10 months ago 2 Members · 3 Replies
  • Sareesh Sudhakaran
    November 18, 2012 at 9:29 am
    Are you able to see the full image on a computer monitor? If yes, then It seems like overscan, which is quite normal.
    https://www.wolfcrow.com – Workflow information and support for filmmakers, photographers, audiographers and videographers.
  • Gašper Gaberšček
    November 18, 2012 at 12:43 pm
    Thank you for your answer.
    Yes, on my computer, the whole 720x576px is visible. After some research I also came to the conclusion that it is probablly overscan.
    So, the only real solution would be to tweak the animation a bit, so it doesn’t fall out of the Action safe area? Or, did I make a mistake in my workflow maybe? I have never downscaled from Full HD to brodcast PAL before, so I found that workflow online.
    November 18, 2012 at 1:09 pm
    When placing animations, follow the safe areas found in your NLE. No problem with your workflow.
