Activity Forums Adobe After Effects Broadcast white problem
  • Broadcast white problem
    Posted by Jcharlss on September 1, 2006 at 8:24 pm
    I recently did a little logo animation that runs on a plasma screen and it has a lot of white space.. the problem is when its on the TV it has a odd blue tint. anyone know whats causing this?? and ideas?
    any help would be greatly appreciated!
    thanks
    jeff
    Mark replied 20 years ago 3 Members · 2 Replies
  • Jason Rouleau
    September 1, 2006 at 9:05 pm
    1- In your comp, scroll over your white area and check in your info palette to see if your white truly is white (255,255,255). If you see more blue value in your white, then thats your problem.
    2- Check to see if your plasma is properly calibrated, play with its color settings and such. Maybe you’re in some mode that gives everything a bluish tint. Consumer TVs are manufactured in a way to try and make things look better. They don’t accurately represent what the original image is.
  • Mark
    September 1, 2006 at 9:59 pm
    Drop the white levels. Add the levels filter and drop the white down to like 235….this should get better results. Pure white is often extremely hard for televisions to display…my JVC buzzes with pure white (not an old tv).
    Good Luck
    Mark
