Activity Forums Apple Final Cut Pro Legacy Broadcast Wave file question
  • Broadcast Wave file question
    Posted by Aaron Neitz on January 24, 2007 at 10:36 pm
    We’re being asked for Breakcast Wave files of a 5.1 mix. I have everything as aiff now, and am assuming from what I can gather on the web that a broadcast wave file is simple a linear PCM, 16 or 24 bit, 48khz .wav file. Yes/no?
    Aaron Neitz replied 19 years, 8 months ago 5 Members · 5 Replies
  • Chris Borjis
    January 24, 2007 at 10:38 pm
    sounds right to me.
  • Neil Ryan
    January 24, 2007 at 11:53 pm
    You didn’t mention the reason you were being asked for files, so, just in case, are you sure you know what they want?
    Do they want the six stems that make up the 5.1 channels or are they after a Stereo mixdown?
    Other than that, your original assumption is correct.
  • Michael Gissing
    January 25, 2007 at 3:16 am
    A broadcast wav looks to many systems just like a wav file. However in some audio systems the embedded timecode stamp can be read and used to sync the file to a specific timecode reference.
    If you need the timestamp then Sebsky tools can convert broadcast wav files to QT files so that FCP can read the timecode.
  • Will Salley
    January 25, 2007 at 4:55 am
    FCP, as of 5.1.2, will read BWF natively.
  • Aaron Neitz
    January 25, 2007 at 6:21 pm
    This is what they’re asking for: Dolby is striking a Dolby Digital track for print:
    I found tools that convert the TC stamp for FCP, but I need to go in the reverse direction – aiff to BWF
    Broadcast Wave files (Consolidated/Flattened, see below)
    *Consolidated/Flattened: Individual Bwav files with matching lengths for each channel (Example: one Bwav file for Left, one Bwav file for Right, one Bwav file for Center ect.) These files are to be completely mixed final sound requiring no additional processing, plugins, fades, or level adjustments.
    16 or 24 bit depth
    48K Sampling rate
    -20dbfs Reference level.
    Time code frame rate matching the sound speed. (Example: NTSC 29.97fps Df/NDF, PAL 25fps, Film 24fps)
    Delivered on a DVD-R, DLT, LTO, M.O. Disk or Hard Drive.
