Activity › Forums › Adobe Premiere Pro › Broadcast Technical Specifications
  • Broadcast Technical Specifications
    Posted by Brian Byrd el on September 13, 2006 at 11:04 pm
    I am preparing a show to be broadcast on satellite TV. Would anyone care to explain these technical specifications from the broadcaster in plain English, and how to achieve these specs in Premiere Pro 2? Thank you very much for any assistance.
    “The tape should have as a minimum, one-minute of EBU 625 75% bars &
    0dB tone(s) – i.e. the tone(s) should be recorded at PPM4 or minus
    4VU. The sound levels on the recording should be in correct
    proportion to the line-up signals and maximum levels should not
    exceed PPM6 i.e. – they should be no higher than 8dB
    Vince Becquiot replied 20 years ago 2 Members · 1 Reply
  • Vince Becquiot
    September 14, 2006 at 9:26 pm
    It looks like these are actually PAL specs. You may have a better chance getting the right answer in the After Effects Forum. There are quite a few more European Mods who should be able to help you with that.
    Cheers,
    Vince
