Activity › Forums › Adobe After Effects › Broadcast Specs
  • Broadcast Specs
    Posted by Kenneth Crawford on July 22, 2008 at 2:37 pm
    Hello,
    I have made a full length animation that has a logo to a TV spot we do. The logo has the color green with an RGB value of B5FF00. I have no way to check the levels of the color in illustrator or After Effects, but when it was brought into an editor it was over 100 IRE. I brought the color down, but it looks so bad that I dont like the green anymore. Its an HD animation that will be broadcast. Is there a way to get a saturated green that doesnt look dark or like its been left out in the sun all day?
    Thank you.
    Kenneth Crawford replied 18 years, 2 months ago 2 Members · 4 Replies
  • Chris Wright
    July 22, 2008 at 8:23 pm
    you’re looking to change an illegal broadcast chroma without it turning ugly. Use a smart interpolater like color finesse or red giant broadcast. There might be a free way to do it and creative cow had something about checking it so I’m sure the tutorial talks about fixing it.
  • Chris Wright
    July 23, 2008 at 8:58 am
    adjustment layer-color correction->levels effect, input black 16 input white 235, ouput black 16 output white 235,
    yea, I watched the tutorial…I’ll compare results someday…
  • Kenneth Crawford
    July 23, 2008 at 2:38 pm
    another question I have is this. If I am working with HDV and my Graphics are FULL HD for this HD show, and we are mastering to HDV when the project is completed. We then send the product to the channel that broadcasts it and they convert it to SD so they can broadcast it, do I need to follow an NTSC broadcast color scheme? They will also use the HDV to broadcast it in HD on direct TV as well.
  • Kenneth Crawford
    July 24, 2008 at 2:02 pm
    Okay thanks for all the information! it really helped alot, and I have checked out that plugin for After Effects and it seems to work very nice. Thank you!
