Activity Forums Adobe After Effects Broadcast source video: 24 FPS vs 29.97
  • Broadcast source video: 24 FPS vs 29.97
    Posted by Jon Buttry on August 9, 2011 at 4:07 pm
    I have been building broadcast spots for a few years now, and I still don’t have clarification on this topic.
    When spots are finalized for broadcast, they obviously need to be 29.97 FPS. However, there seems to be this huge push to shoot at 24 because of the “film” look being preferred over the 29.97 “video” look. Many production companies are submitting footage shot on newer DSLR’s, and more often than not, they shot at 24. So the issue is, when converting 24 fps footage to 29.97, what is the “best” way? I have tried…
    1. Edit spots at 24 FPS, and then export the final edit to 29.97 using a field render (upper first) and WSSWW for the 3:2 pulldown. This results in ugly interlacing in the final product…
    2. Interpreting the imported footage shot at 24 FPS as 29.97 FPS footage, using the 2:3 pulldown. This is rough because I’ve had to do special fx frame by frame, and you get the issue of repeated frames with the pulldown. However, no ugly interlacing upon final export.
    Which way is the “industry standard”, or is there a better way that I’m missing?
    Thanks much in advance!
    Jon Buttry replied 15 years ago 1 Member · 0 Replies
  • 0 Replies
